Possible to set clock/weather as standby screen?
Hi. I was wondering if it is possible to use the clock/weather screen as a standby screen?
I have the 201E, and use an external dac. When I turn of the dac, the 201E ask for the dac and then wont show the weather screen for more than a couple of seconds. But if I set the 201 in standby mode it won’t ask for the dac, only problem is that I can’t seem to use the clock/weather screen in standby mode.
Am I missing something?
Best regards Hajans
@Hajans
You cannot set a screen that displays the weather in standby mode on Rose devices.
Select the clock you want in Settings–>Display–>Always on display.
Then, the selected clock screen appears in standby mode.
