Power Consumption of RA180
May I know the power consumption of the RA180? I need to know since I have to eliminate if the loading of my conditioner was sufficient for all my stuffs together with the RA180. Thanks !
@Allan
Since power consumption always varies depending on the environment and conditions of use, it is difficult to give an accurate measurement value. The input voltage is AC100-240V, 50/60Hz, and the power consumption in standby mode is less than 0.5W.
Ok I am thinking whether it would be more or less the same as the RS520, which has be told from the spec it has 150W in consumption.
