What’s the right way to power on/off simultaneosly the RS130 & RD160? Does the usb optic fiber support this function? Thank you all.
Hello, thank you for your inquiry.
The RS130 is equipped with only one SFP port, so as you mentioned, an SFP connection can be made with only one device at a time.
That means:
- RS130 to RD160 via SFP, or
- RS130 to RSA720 via SFP
You must choose one of these connections, and it is not possible to connect all three devices (RS130, RD160, and RSA720) simultaneously using SFP cables.
If you need to connect additional devices, please use other available interfaces such as USB, coaxial, or optical connections for the remaining components.
If you would like further assistance with system configuration or recommended setups, please feel free to share your full system details and we will be happy to help.
thank you for reply.
I just wanna know if there is a tip to power on and off simultaneously the rs130 & rd160. only the rd160 have a trigger in/out. So how is it possible to control both ?
thank you again
The RS130 and RD160 can be connected via a trigger.
On your RS130, please go to the system settings and set “USB/SSD power activation in standby mode” to OFF.
With this setting applied, when you turn the RS130 off (standby), the RD160 will immediately power off as well.
