JMBARG and BorisM. I have set the mv to 2000 and everything sounds fine so I will leave it that way. And finally what is the best filter setting for jazz music? JMBARG, yours is Min Phase Slow Roll off or have you changed anything in the meantime ?
Boris likes to annoy and disrespect everyone; when God created the universe, he also decided to create Boris, so he could be above us all. We should be grateful for his existence.
FONZ:
Filter: It is my personal taste, to use the filter that I told you about (to my understanding and perception, it gives me warmth, texture, spaciousness and things sound like me, I like them to sound), I use it for all my music: Jazz - Rock - Classical - Electronica. I play exclusively from an external USB 3 hard drive, which contains 1 Bit DSD Vinyl Rips - 32 Bit WavPack - SACD ISO Files - 16 - 24 - 32 Bit Flack & Wav. I never connect the equipment to the Internet, in my case it is a DAC with display.
I get it. Thanks for your help. it is much appreciated.
FONZ.
At the end of the day, itâs your ears and your tastes that rule, the rest is all just stories.
2V should be a perfectly fine setting. Unless you have to turn up the volume on the Naim far more than with other sources, might as well keep it there.
As far as filters go, it is very unlikely that you would actually hear the difference. And it does not really depend on what kind of music you are listening to. Slow roll-off filters are, well, slow and start dropping frequency response at relatively low frequencies. Thatâs what makes them âwarmâ â thereâs no treble. Of course if your hearing is similar to that of a normal person and you arenât a teenager, you wonât hear any difference either way. Pre-ringing might be more objectionable, so Iâd chose any of the short delay filters.
Maybe if you were capable of somehow preventing yourself from posting obvious nonsense like " 1000mV (500mV per channel)," or implying that storing your music on a USB 3 disk or not connecting to the internet has any effect on sound quality, then there wouldnât be any need to ridicule you.
Nunca dije que al no conectarse a internet se obtenga mejor calidad de sonido.
Seguramente debes tener muchos problemas en tu vida y en este foro, es en el Ășnico lugar en dĂłnde puedes hacerte notar. Boris, me das mucha pena, se nota que no eres una persona feliz. Continua insultado y faltando el respeto a todos, de mi parte te lo permito si es que te ayuda a ser menos infeliz.
âŠand the show goes onâŠ
Where are the flags⊠raise the flag!
I contacted NAIM and they advised 2000mV (Same mV as their own NDX2 streamer) so problem solved. Thanks everyone for helping me out.
Sorry, cabron, but as much as it might wound your sense of self-importance, existence of people with negative IQ, like you, while slightly annoying, does not make anyone unhappy.
