I set too high pre-out setting level for my amp and now I can not turn off pre-out setting level. I swittch to off and apply but it still remans on.
We do not have the same phenomenon as you.
- Please tell us the Rose device model name you are using.
- If you set the pre-out level to a different value than the current one and press the OFF button and apply, does it remain ON?
- Does the same phenomenon occur after factory resetting your Rose device?
- Rose device name Rose-65. Rose ID:0D1465
- Yes
- I don’t know. After factory reset I don’t want to try again to avoid next factory reset
Please answer some additional questions.
Are you changing the pre-out level setting through the Rose Connect app? Or are you changing it on the Rose device itself?
Rose-65. Rose ID:0D1465 is not the Rose device model name. Please tell me your Rose device model name.
Rose device–>Settings–>System info–>Model -
If this problem occurs on the Rose device, I recommend a factory reset.
