HiFi Rose RS520
Bruker dali icon 12" aktiv sub rca kobling
har noe tips om setting pre-out
jeg spør for de jeg må bruke fult volum på suben
HiFi Rose RS520
Preout level setting is only available for analog output.
The output value will be fixed according to the set value. When this setting is applied, you will not be able to adjust the volume on ROSE, so you need to adjust the volume on the amplifier. When setting the value, please check the “input sensitivity” of the amplifier you are connecting to and set it to a similar value. If the output is higher than the input sensitivity, clipping and distortion may occur.
