In th OUTPUT SETTINGS menu on the rose 150b, I was wondering if you switch the toggle to "OFF " on PRE-OUT LEVEL SETTINGS what is the voltage output that feeds my terminator dac?
If you turn the pre-out level setting OFF, full voltage output will be provided regardless of the volume setting of the RS150B.
Approximately 4 Vrms is output from the XLR port and approximately 2 Vrms is output from the RCA port.
