Here are my answers:
The unit is a HiFi Rose 250 and it is running the newest software installed at the beginning of the week.
The output is connected to my amp via unbalanced analogue cables.
The unit has a digital input from my Naim Core and a network cable going to my router. Also, your CD drive is connected via the original USB cable.
The following is happening
A. The problem with the low volume via my speakers always happens when I switch on the unit from stand-by mode, but not every single time. It does so quite regularly.
B. The problem related to the headphones is strangely enough the other way round. Here and there the volume for the headphones goes to maximum once I connect the headphones after a listening session via the speakers. It also does happen after I switch the unit on from stand-by. Once again, not always, but quite regularly.
Bruno
