Hello fellow Hifi Rose users. @ROSEHAN @ROSELOA
I have the age old question regarding the preamp settings when connecting a external headphone amp.
I plan on using two headphone amps with my HifiRose 150b and setting the 150b to fixed volume while using the variable volume of the headphone amp(s). Keeping in mind one amp will be connected to the 150b at a time not both.
Headphone amp 1:
Input sensitivity (XLR balanced in / out)
9.3Vrms @G=L
3.0Vrms @G=H
Headphone amp 2: (XLR balanced in / out)
Input sensitivity
18 Vrms @G=L
What should I be setting the 150B preamp to based on the above input sensitivity of the above two amps keeping in mind I can change the preamp output on the Hifi Rose 150b per external amp as needed.
I appreciate the sage advice in advance.
