Problem installing SSD
Trying to install above referenced SSD on new RS520
When I hit SSD format
I get error
SSD not available
Please check the SSD
Faulty drive??
I guess the RS520 can not recognize the SSD.
Would you check if the file system of the SSD is NTFS?
You can check it by connecting to PC, or check the SSD manual.
It wasn’t seated properly
I put it back in at an angle before
I pushed the cover closed
Did the trick
