Hello , i have a problem when i listen tidal on my accuphase e4000 / dac50 With rs 130 . Connected with coaxial cable.
When i change track on tidal a click sound is produce by dac and the track begin . The click sound is not listen on vidéo track just on to music .any ideas ?
Sorry for my bad english.
I have exactly the same issue when I use Weiss DAC .No such popping sound when I use USB connection on RS130. Only on RCA connection.
Please check a few things.
- Does the click sound only occur when the track is changed from Tidal?
Does the click sound occur when the track of Qobuz, external hard drive, or Apple Music is changed? - Does the click sound occur even when the RS130 is connected to your external DAC other than the coaxial connection?
- Does a click sound appear when the Tidal sound source ends and the next track is automatically played? Or does the click sound occur when you play a different track?
- Does the click sound come from the DAC rather than the speaker?
Please provide a more detailed explanation and answer.
@ROSEHAN :only happens when I use RCA connection. Only happens when I use internal and external hard drives. Only happens when switch sound trucks. I don’t use streamer at this moment. The click sound or popping sound is from my speakers.
Hello , i have only coaxial connection and yes to question 3 , it s the same on qobuz .
The click is just on dac not on the speakers .
It came between 2 tracks or on playlist after change track automaticaly.
The click des not appear on vidéo track .
Thank.
I make a short vidéo if You want ?
The click sound is like a relay sound not pop or click in the music he is material
When changing songs, a clicking sound from the DAC usually occurs when the sampling value changes.
In/Out settings → Gear-shaped button on OUTPUT → PCM Resampling frequency will be set to Auto. Instead of Auto, set it to 192kHz or lower and click Apply in the upper right corner.
Does it still happen the same?
After making these changes, I have not heard the popping sound from my speakers when the sound track changes.
Thank you so much!
Hello , i have tested all rate sampling and the click on the dac appear. It came when the value sampling change for every tracks.
On usb connection the click appear
@Nicoz91 :Have you tried another DAC with RS130? There is no relay switching for a DAC when change the sound track if there is no resolution changes. I have tired at least 5 DACs with RS130, there was no issue with my DACs.
I am glad that the popping sound from my speakers resolved.
Good luck !
Has this been resolved, I am having the same issue and we should not have to lock down the sample rate. IT should be able to adjust same rates without issue and no pops. I am having this on i2s but not on USB. There is obviously something going on with the mute stage of the rs130 on outputs other than USB.
Hello , mqa is the problem for me .
With qobuz and the sample rate Locked at 192khz.
The dac no click
