Problem to play local files over i2s
Hello HiFi Rose,
My current setup is connected RS130 to holo audio may kte over i2s or usb
Streaming with the RS130 as roon endpoint over i2s to holo audio may is fine but I experience problem when I play local files in RS130 over i2s to the dac, the dac shows the link is “unlocked”
There is no problem when I play local files to the dac over usb.
It is very strange. I don’t have any issue over i2s when use RS130 as roon endpoint.
Does the RS130 support to play local files over i2s, or are there some problems with my RS130?
Pls advice.
