Problem to play local files
Hello HifiRose,
I am using Holo Audio May DAC connect to RS130 through I2S or USB. My DAC occasionally unlocked to RS230 over i2s when I play local files on RS130, but never has an issue when I use RS130 as Roon endpoint. Interestingly, when I have the unlocked problem playing local files, I switch to USB and the problem gone. No issue to play local files over usb so far.
It is frustrating, especially I believe I would have better listening experience when play the local files. I can’t figure out what’s went wrong, especially the problem is “occasionally”, please advise.
KK
@Kktong
We also have the DAC you are using, but no matter what connection you make to the RS130, it does not show the same symptoms as you.
Please check a few things.
  1. Are you having a problem where the local file is played normally on the RS130 but occasionally unlocked?
  2. How often does this symptom occur?
  3. Does the same symptom occur when you reconnect the HDMI cable or turn the DAC off and on when unlocked?
  4. Which local file did you play, PCM/DSD?
  5. RS130–>Music–>Gear icon on the bottom left (Settings)–>Media Library–>DB initialization–>Rescan DB
    Does the same symptom appear even after rescanning after DB initialization as above?
  6. Do you see the same symptom even after factory resetting the RS130?
