I recently changed amplifiers (I went from an Accuphase E250 to an E280).
Unfortunately JUST REPLACING THE Amplifier (so I just removed the old one and mounted the new one using the same cables in the exact same position) I found that the speakers emit a “hum” or “hum” as soon as I turn on my Rose RS150B and this “noise” comes from the unbalanced signal cables connected from the Rose to the accuphase.
I did a test and this happens with both balanced/unbalanced cables or even USB from an EXTERNAL DAC CONNECTED TO THE ROSE!
I tried to connect another source from another brand (a MARANTZ SACD player) and I connected it to the same input that I used to connect the ROSE and this problem is not present with the Marantz (so the noise comes from the Rose itself)
What do you recommend me to do?
I read in the forum that I’m not the only one who has had this problem…unfortunately…
