Problem with All Play in app
Since updating the Rose connect app last week my RS250 will only take the all play instruction by manually selecting it from the device on the front panel. If you try and use the all play function from the app on either iPhone and iPad it just selects the first song and that’s it. It won’t play the whole album or add it to the playlist. Checked all settings are the same and rebooted the machine. Seems like an app update issue as the machine works as it should. Anyone else having this issue? RS250 playing files from a 2tb Samsung SSD
Seems like you’re using the ‘Play from here’ option in Rose APP.
(Rose APP > Settings > Audio Settings > Song play options > Play from here)
There’s problem with this feature right now, software team is working on it.
I apologize about the issue and inconvenience.
