I will explain my HDMI connections to see the video and hear the audio:
SYSTEM ONE: ( PROBLEM )
Video + audio 2 channels:
-Out HDMI ARC (RoseRS150B) -> In HDMI NO ARC (my Sony AG9 Bravia TV).
-Out RCA (RoseRS150B) -> In RCA my amplifier (Audio Analogue Maestro 70).
With this type of connection the audio works perfectly but the video can only be seen on the Rose RS150B even if the button at the top right of the Rose which is used to switch the video from the Rose to the TV IS ENABLED in "ON".
ATTENTION: this connection on my old RS 250 works perfectly but now, by simply replacing it with the new RS150 and using the same cables, the system no longer works.
SYSTEM TWO: ( NO PROBLEM )
Multi-channel video + audio:
-Out HDMI NORMAL (RoseRS150B) -> In HDMI NORMAL (MARANTZ SR6007 home theater amplifier).
-Out HDMI ARC ( Ampli MARANTZ SR6007 ) -> In HDMI ARC ( TV SONY BRAVIA AG9 ).
Changing the output setting on the RS150B's touch screen panel from RCA outputs to HDMI output with this connection works well for both audio and video.
Hello
I’ve sent you an email. Please check your email.
Hi! I have the same problem. What is the right decision?
Tank’s
Hello
Connect the TV to the HDMI port on the back of the RS150b with an HDMI cable.
Set the HDMI resolution to a lower resolution first. If your TV doesn’t support 3840*2160, you won’t see it on your TV.
Check if the HDMI port on the TV and the external input signal are the same.
