Problem with Tidal Cache after software update
I have another issue.
I reset the software to original when I could not get any sound from my RS150b, which is why I needed to log in again to Rose Radio. I have now figured that out.
Next problem:
I use Tidal and have been using the caching feature. It is now turned off.
When I attempt to turn it on again, it asks me to select the path for caching. I have a folder on the RS150b internal hard drive named TidalCache that I have been using for this purpose.
When I select this folder, the message “that path is already in use.”
At this point, I don’t know what to do to use this folder again as my Tidal cache.
Can you help me?
@oilheadoug
When setting the Tidal cache directory, selecting the parent folder rather than the existing ‘TidalCache’ folder should resolve the issue
This corrected the problem.
