Problème avec Télécommande
Sur RS250A acheté en 2023, difficultés à passer en pause ou en lecture avec une vidéo dont le fichier est sur un disque SSD dans le compartiment sous le RS250A, alors que ça marche avec les commandes de l’écran tactile.
Cela semble avoir un lien avec l’utilisation ou non de la mise à jour de l’appli VLC
Pas de problème avec les mp3
Avez-vous ce problème et une solution ?
@AlainM
Does the same symptom occur even if RS250a–>Video–>Settings–>“Use VLC Player” is set to OFF?
@Flash
Originally, pressing the power button on the Bluetooth remote control does not turn off the Rose device, but puts it into standby mode. When the Rose device is completely turned off, you cannot turn it on using the remote control. However, in standby mode, you can turn it on with the remote control.
  1. Exactly what screen are you unable to turn on with the remote control?
  2. When the power is completely turned off and turned on, does Bluetooth change to OFF? Or has the pairing with the remote control been lost?
@Flash
I see this as one of three problems.
  1. Please factory reset RS150b and check if the same symptom appears.
  2. Please replace the batteries in the remote control with new ones and check how they are.
  3. If you have tried both of the above and they still do not work, contact the distributor where you purchased the RS150b and request a new dongle and remote control.
    eng.hifirose.com/Distributors
Good morning,
yes the problems also exist if “Use VLC Player” is set to OFF"
To read to you
