Hi when select a playlist in Qobuz connect using my Rs130.
First track plays okay but the 2nd one the RS130 switches into mute.
And that’s for every following track. I can turn it off but then the next is muted again.
Any way to fix this?
This issue has been forwarded to our software team for investigation.
As soon as we have any updates, or if additional information is required, we will contact you.
@Herman63
Regarding your inquiry, we have tested the issue and confirmed that when playing via Qobuz Connect on the RS130, the next tracks play normally without any issues.
To help us investigate the root cause further, please provide the following information so we can look into it:
- RS130 Software Version and ROSE ID: Can be found under Settings > System Information
- DAC and Output Information: The specific DAC model you are using and your current audio output settings.
I’ve updated to the latest software and my problem seems to be solved.
Thanks for the quick response.
Regards
Thank you for sharing the test results. If you encounter any other issues while using the product, please let us know in the comments."
