Avevo già avuto questo problema ma lo avevo risolto ripristinando le impostazioni di fabbrica, ora non funziona neanche dopo avere ripristinato le impostazioni di fabbrica !
Please check if you have updated FIRMWARE for your player to version 5.9. If not, update firmware. Which player you have?
Yes I have version 5.9.2…
My streamer Rose RS150B tells me this is the latest firmware available but it doesn’t work.
If you are experiencing the error message ‘could not connect to media route’ when playing Qobuz, please check if the same symptom occurs even after setting it as follows.
Rose device–> Settings → Date and Time → Daylight saving time → Off
Finally, reboot your Rose device
We have the updated file that fixes the issue related to Qobuz Connect.
It is not yet released.
If you want the updated file that fixes the issue related to Qobuz Connect, please let me know your Rose device model and software version by email below.
Then I will send you the updated file and how to update.
Rose device model
Rose device–>Settings–>System info–>Model -
Rose device model
Rose device–>Settings–>System info–>System version info
Ciao Han, grazie per interessarti alla risoluzione dei vari problemi che affliggono il mio ROSE RS 150 B.
Ho fatto l’operazione che mi hai consigliato di fare sul daylight saving time, ho messo in OFF la funzione ed ora qobuz connect funziona !!!
Currently, Qobuz connect requires Daylight Saving Time to be turned OFF, but in the next update, it will connect regardless of Daylight Saving Time.
