Have the same problem on my RS250 streamer than many other users are reporting on different models.
My 250 is connected via ethernet to the wall. The Qobuz Connect app is on an iPad using wi fi.
The Rose 250 does not show up in the latest Qobuz Connect app. The app does not “see” it.
I also tried switching the 250 to wifi so that both the streamer and the app are on the same wifi network. No luck. Nothing.
It only works if I use Apple AirPlay, but this sounds terrible.
I am not sure why a Hi Fi Rose rep would state that there are no plans to enable this much sought after and much requested feature, and yet Hi Fi Rose shows up under Qobuz Connect’s certified brand list and, as a previous post confirms, some users are able to make this work.
If I use the built-in Qobuz tab on the Rose Premium Connect app, playback is a mess and it skips constantly. So all of the above is not only confusing, it is also supremely disappointing.
I may just sell my 250 unless things improve quickly.
