Since the last update, I’ve been having issues with Qobuz Connect on my iPhone; I can’t get it to show up on my Rose C8. I even restored the 130 to factory settings, but the problem persists. I have to turn my iPhone off and back on again to get it to work. Is anyone else experiencing this?
Could you please answer the following questions so we can investigate the issue further?
- Which ROSE app are you currently using?
- RoseConnect Premium
- ROSE ONE
- ROSE EA
- If you completely uninstall the ROSE app from your iPhone and then reinstall it, does the same issue still occur?
Please let us know the results.
Good morning, Everything resolved. I reset the Rose RS 130, restarted the router, and restored the iPhone 17 Pro’s network settings. Now everything works as before. Thanks. Have a good day.
