Since RoseApp does not support Cromecast and Tdalconnect, How can I integrate my already existing Playlists, Favorites, etc. from Qobuz and/or Tidal?
I figured out meanwhile but still lack some features.
Will it be possible to modify my Qobuz playlist frim the RoseApp?
Although I really dig the sound of the unit, those are features I regard as essential…
I’m sorry, Qobuz plalist currently stored in Rose cannot be moved to other devices.
This feature seems difficult to improve.
Dear Rosehan,
it is not what i am asking, i use the Qobuz playlist from my RoseApp and woul like to have the opportunity to add or delete Track in the QOBUZ! Playlist…
Kind regards
I’m sorry for misunderstanding.
You can delete or add songs in the Qobuz playlist in the RoseConnect app.
- How to delete the tracks from Qobuz playlist.
RoseConnectPremium app–>Qobuz–>Qobuz Home–>Scroll down My Playlist–>View all–>Select the Playlist you want to delete a track–>For each song, click the 3-dot button on the right at the top Press the 3-dot button–>Edit Playlist–>Click the trash can button on the right side of the Edit list below, select the track you want to delete and press Delete.
- How to add the tracks to Qobuz playlist.
From Qobuz, please click the 3-dot button to the right of the album or track you want to add to the playlist and click “Add to Playlist”. Then, Create New Playlist at the top and created Playlist lists at the bottom appear.
If you want to add a new playlist, click Create New Playlist to create a playlist and click Complete to complete the addition. And if you want to add to the previously created Playlist, select the previously created Playlist and click Complete.
thanks a lot, not sure why it didn’t work last time i tried, but you are right, i could follow your tutorial.
Thanks again, love it !
