Warum können in der Rose Connect App die Qobuz-Alben in den Favoriten (Mein Qobuz=>Favoriten=>Albums) nicht sortiert werden. Sie werden in der Reihenfolge des Hinzufügens angezeigt. Für die Nutzung nicht brauchbar.
Why can’t Qobuz albums be sorted in the Rose Connect app’s favourites (My Qobuz=>Favourites=>Albums)? They are displayed in the order in which they were added. This is not practical for use.
Your issue has been forwarded to our software and hardware teams.
As soon as we receive a response, we will let you know immediately.
Qobuz does not provide a Favorites API, so we are currently unable to add this feature.
For now, when you enter the “View All” section of your Favorites, you can use the search function, which we recommend as the primary method.
If Qobuz begins providing a Favorites API in the future, we will add support for it.
Hello
Thank you for your feedback. Unfortunately, however, I don’t quite understand.
When I mark my Qobuz albums as favourites, they appear as ‘Favourite Albums’ with the name of the album and the artist.
Why is it not possible to sort the albums by artist name in this view?
… simply the same display with the same filter options as for my scanned albums …
In Tidal’s view, it is possible, but unfortunately only the name of the album appears and the name of the artist is missing.
Kind regards
Martin Kindler
