Question about standby and Power off
Hi!
In standbymode how do I power it of ? When I push the on/off button in standby mode on top off my RS130 no power off (in red) pops up. ( I does so when its on) If I hold the button it will reboot . How is the best way to total power it off in standby mode? Can go from stand by mode to power off without set it on first? Happy Rose listning this weekend :slight_smile:
I once suggested here that a long press on the power button either on the device or RCU remote control should power of the unit.
On my RS130 when I hold down the power button (the one farthest right) 3 options pop up after several seconds: Turn off display, Reboot, Power Off
Does it do so in stand by mode also?
To power off RS130, see RS130 User Interface - #98 by joyofmvid
Thanks Joyofmvi! But that does not say anything on how you can power off from stand by mode, as I understand it I must go from stand by to ON to be able to power off the RS 130
