Aww, poor smegmel. Can’t argue with facts, being this ignorant, but he did learn to hit the flag button, like a good little monkey!
Yes, we all already know that you are denser that a uranium ingot. Do you also buy horoscopes, because anyone can google horoscopes for sale, so they absolutely must be real!
That you are not capable of looking up CAT7 standard that quite clearly states that a CAT7 cable (if it is CAT7 and not something sold to brain-dead audiophools like you with a “cat7” label) should not and will not plug into an RJ-45 jack… well, that’s your problem, although your insistence on making sure that everyone knows that you are neither competent nor intelligent is surprising.
How do you “play sound” through two DACs? Or did you already forget what you wrote? Which you likely did, being senile and all.
If you believe in magic, maybe you should put up your Depends (so as not to embarrass yourself even more) and hang out at Disneyland? Would be better for everyone that you spouting nonsense here.
At least Amir knows what he’s talking about, unlike you.
