Queue Management
I have noticed that the items put in the queue are never automatically removed, even after playing the items with “repeat” set to off.
Is this the expected behavior or if there is any setting that can remove the item in the queue after playing?
Queue is a list of songs you are listening to right now. Songs added to the queue do not disappear once done.
The “repeat” function is divided into “repeat all” and “repeat one”.
“Repeat all” is a function that repeats all songs in the queue in order. (unless you turn on shuffle mode)
“Repeat one” is a function that plays only one song repeatedly.
Queue will be empty if you reboot your ROSE device.
Thank you,
Many thanks for the prompt reply. Much appreciated.
Perhaps, in the future, HiFi Rose can consider adding an option for users to choose if they want the played songs to be removed from the queue, if none of the “repeat” function is not turned on. This will be more consistent with the behavior of other media players on the market, I think.
Happy to hear other users’ views.
@ googzzhk, je suis entièrement d’accord avec vous, cela serait tellement mieux de proposer dans le menu une possibilité de suppression de la file d’attente !!!
S’il vous plaît, poster sur ce sujet, merci !
