RA280 and subwooferconnection
I am confused regarding the subwoofer-output of the RA280. Some say its a fixed signal other says its not? If it is a fixed signal, then the subwoofer volume doesn’t change, when you change the volume on the RA280, right?
@jazzjan
We are here to answer your questions.
In the case of RA280, the subwoofer volume changes and is output.
