Radio Station URL don't work
When I enter the station URL, it states “won’t play at this time”.
Can you add KDFC in San Francisco, California, WFMT in Chicago, Illinois, and KAZU in Carmel, California
Hello
KDFC: https://listen.181fm.com/181-xtraditional_128k.mp3
KAZU: https://playerservices.streamtheworld.com/api/livestream-redirect/SKYRADIO.mp3?dist=radionet
Please try to use the web address written above
Thank you. Neither one seems to work. I don’t even get a temporarily unavailable notification.
Both channels that dushbag96 uploaded works well with ROSE device.
What error do you see when you add the channels above?
Thank you. When I go to Radio screen, press “+”, and enter then name and url and press confirm, the screen goes back to where it was before I pressed “+”. There is no change on the display of the unit itself either. 2 other things, there is a small red dot on on the iPad app just under the url (I didn’t put it there) and when o click on the link provided on my phone I do get a station but it is t the classical station I was looking for.
Any chance you could put those stations on your end?
I just tried it on my phone instead of my iPad. I got the first one KDFC to work but it’s not the correct station. The second one KAZU still doesn’t work.
When you copy the radio address to address bar in internet, can you play it?
On my phone when I click on the links they both work (the first is Christmas music and the second is in a foreign language). But neither is the radio station (classical music) I am looking for.
On the Rose unit only the first one seems to work - but again the wrong station.
Really appreciate your help!! Thanks!!
Check if these are the channels that you’re looking for.
KDFC : http://25083.live.streamtheworld.com:3690/KDFCFM_SC
KAZU : https://icecastle.csumb.edu/livehd2high
You are a genius! They both work!
If I could get link to WFMT in Chicago Illinois then I would be all set!
Thank you!!
WFMT : http://stream.wfmt.com/main-mp3
That works perfectly. Thank you very much. Grateful for your help.
