Thank you for offering this opportunity. My HiFi Rose 130 outputs to Aqua La Scala via AES/EBU. Input to Rose is WiFi. Internet is Starlink. I have listened through the Rose all day using an iPad Pro as control. Next day, HiFi Rose cannot connect to iPad. iPad connects to internet, Rose connects to audio network, WiFi, plays beautifully from Rose touch screen. I have changed nothing. Next day, again, Rose will not connect to iPad. BUT, in addition, Rose will not play from touch screen. These quick, less than on second error messages flash, Sound output not good, check input/output. I go to settings and all appears to me to be correct. Once again, I have not made any changes to the network or anything. Any ideas? In over my head.
RS130–>Settings–>System info–>IP address
iPad Pro–>Settings–>Connections–>Wifi–>IP address
Example) Correct
galaxy tab A IP Address: 192.168.4.33
Example) Wrong
galaxy tab A IP Address: 192.168.6.33 -
Delete and reinstall the RoseConnect app installed on iPad Pro.
Check if the same symptom appears even if you factory reset the RS130.
Thank you so much.
iPad- 192.168.1.25
Rose- 192.168.1.30
Tried manually changing iPad to 192.168.1.30 nothing.
Rose sees iPad. iPad no longer sees Rose. Tried reinstalling Rose Connect on iPad, nothing.
iPhone and Macbook both work with Rose fine. So I give up on iPad.
Apple often does not play well with others
