RD 160 no Remote Integration
The RD160 seems to be a stand alone solution referring remote and trigger-Integration to RA 180 and RS 150 B.
The set sounds nice, the set integration is unfortunately poor! Any improvements planend? @ Rosehan Thank you for your quick response
@Dirk64
You are correct that the RD160 currently functions as a standalone unit in terms of remote control and trigger integration. We understand that deeper integration across HiFi ROSE components—especially for remote commands and power synchronization—is important for a seamless user experience.
Please rest assured that we are actively reviewing user feedback and exploring development improvements to enhance inter-device communication and integration in future firmware updates and product iterations. While we cannot share a specific timeline at this moment, system-wide connectivity and usability are priorities for our product development team.
