RD160 Display Text (Auto dims)
Hey Everybody,
Is there a way to prevent the display writing from dimming on the RD160.
I want it to stay on.
It dims and disappears after 3 minutes.
Then when I want to engage with the DAC, for example I want to MUTE. I press Mute- it wakes the display up- then I have to press mute again for the function to register.
Hi ret,
As far as I am aware you cannot carry out your request on the 160
@RET
We would like to support this feature as well, but for OLED protection, we have made it so that if you don’t touch the screen of the RD160 for up to 3 minutes, it will slowly turn off or enter Sound wave mode.
In the case of OLED, if you leave it on the same screen for a long time, the previous screen may remain even if you change to a different screen.
