I would love to see a future update for the RD160 give the ability to have the LED on the power switch off when the power is off. I have too many little lights on devices all over the house and one less on the stereo would be great. This could be added to the Menu.
Your request seems difficult to reflect.
Not only RD160, but all Hi-Fi Rose products have a power switch that lights up when the power is off so that you can confirm that the power is off.
I guess my experience is only with the RD160 and the RS130 but I don’t see that the RS130 has any light on when powered off. So not every Rose product has a light when off. The RD160 is the only unit on my rack that shines a light 24 hours a day.
In the case of RD160, when the power is connected and the OLED is off, the power button light turns on. When the OLED is on, the power button light turns off.
If you experience any other issues with your RD160, please take a video and send it to the email below: eunseong96@citech.kr
Thanks for the response. I understand how it works and when it is off and on. What I am making a request for is that there be an option that the power light is off when the unit is off. Our houses are filled with unnecessary little lights that can’t be turned off.
I understand. I just wanted to make sure you understand what some of us want in a “wish list”. And if the software/hardware can turn the power light off while the unit is on, it should be able to be added to the menu to have a choice if it is off or on when the unit is off I might argue.
@ROSEHAN I have a feature request which is in software. I would like to be able to disable the inputs that are not connected or being used, so when I cycle inputs, I don’t have to cycle through unused inputs. They can still appear in the list on the display, but maybe dimmed, and the next/prev input buttons on the remote and device with skip over them.
