RD160 I2S configuration
Can I get an official reply on the configuration for the I2S pin for the RD160 I2S input?
I’m trying to get a custom I2S cable, but having trouble on getting the pin config right. Isn’t it a basic spec that should be listed on the manual?
I use an standard Audioquest Vodka and it is working very good.
@likwacheng
Please refer to the image below.
The RD160 I2S input configuration is identical to the I2S output configuration of the RS151, RS130, and RS150B.
Is it mode A or B on the RD160?
@likwacheng
The RD160 supports I2S Mode A configuration.
We understand your feedback regarding the lack of detailed I2S pin configuration information in the manual, and we will forward your suggestion to the relevant team for consideration in future documentation updates.
