RD160 - New firmware 1.34 out now!
RD160 - New firmware 1.34 out now today!!!
Hope there is more in there than what is stated, like fixing the SFP connection handshake with the RS130.
After powering on, when playing RoseTube on the RS130, the “To Data” shows 96kHz, but it is displayed as 88.2kHz.
Pretty easy to do once you’ve done it once. If anyone has issues trying to download on Safari on a Mac, you get the wrong filename for whatever reason. Download on Chrome and it is fine.
Carnelian,
Thanks. Easy peasy upgrade. OK, now any idea of what was changed, upgraded, new features?
StndardModel
It says on the download page: “After powering on, when playing RoseTube on the RS130, the “To Data” shows 96kHz, but it is displayed as 88.2kHz.”
Is that all???
No idea. But certainly sounds fine. The other thing to remember is to reviews the settings since they need to be reset after the update. I’m for regular updates even if they are minimal. But I would also like to see all the changes in a change log or some other format.
This update is screwed again. Now whenever I start the music again after stopping it, the screen lights up, which is very annoying.
I had problems with this update: clicks when playing songs of different resolutions. I come back to 1.26.
I wrote to hifi rose about this problem and am waiting for a response.
Are you using the waveform screensaver? I only have a few data points but when I turn off this screensaver I see similar behavior. Moreover, when the screen spontaneously illuminates in this mode the to/from sampling fields show null values. Could be a corrupted firmware update?
Harris
I use the screen off mode. After stopping and changing the song, the screen will light up. This does not happen in version 1.24.
1.26 is good.I have no répons from Rose for m’y problèmes with 1.34.
