I cant found where to download RD160’s USB driver. Is it the same as the asio driver of rs150?
Have you checked after installing the drive below?
RS150(B) / RS250 / RS520 / RD160 users, after connecting the streamer and Windows PC with USB,
you must install the ASIO driver required for high-quality sound source playback.
The driver used for RD160 and other Hi-Fi Rose streamers is the same.
After I install the driver, it cant’ find the rd160. I uninstall and install many times and still didnt work.
Please request the ASIO driver required for RD160 to the email below.
