RD160 - Which filter do you use?
What is your set up?
Yes, this is clearly a different league. As impressed as I was with my Gustard x30, it’s definitely a class below the Rose.
I want to qualify that this is only my experience in my system, and the Gustard x30 is an outstanding DAC and I could live with it happily as well.
Yes, you are right.
I missed that part since I’ve been using Variable (default) after briefly tried 2V for the RA180.
I borrowed the Rd160 for 3 days to test it and compare it to the Rs150b
I then bought the Rd160
It is a very analog rendering, the Rs150b is dry, the Rd160 wider
On the drum toms it is very sensitive
The Dac Rose is now not far from 100 hours of operation, I was able to pose last weekend for some listening
As I specified during the test at home, the difference that immediately jumps to the ears is the battery strikes!! It’s full, ample. With the Dac of the Rs 150b it’s drier
I find the aeration, the stage width, the superb transparency and this dynamic while having a beautiful softness, a very deep bass (it was already excellent with the Rs150b) the holding of the latter with the Dg68 (Accuphase) is impressive.
The differences appear:
-On the voices, still so superb but a little better “integrated”, forcing the line: less projected but it is marginal because already very good before
-The consistency of the medium or high bass is more physical, less dry, in short a very analog rendering
-The depth of the scene as a result that gains
In terms of use and practical side it is perfect, the screen can turn off after a few minutes of operation and it is therefore very sober, I do not use upscale, the default setting is “By pass” and I also use the original filter (not sure to hear differences between each)
The setup is simple and intuitive, it allows for example to choose between a variable or fixed output level with levels between 1 and 9 volts in Xlr (half in Rca).
The aluminum remote control allows simple and easy access to all settings (setup, dimming, filters, upscale, volume if necessary)
The finish is excellent as on the other devices in their range, the aluminum parts are very thick and perfectly treated.
The Accuphase E5000 amplifier accepts 5 volts as input, I set the fixed output to 3 volts to be close to the “standard” outputs of the brand’s sources which is 2.5 v
Guys, I need your help with the correct voltage for the Luxman 507Z. Thanks!
3 ou 4 v en XLR
I put 4 volts on an Accuphase amplifier
I have been testing 3v 4v and 5v. To me 5v is clearer and hear more small detail easier, however, not sure if it is overloading the signal
4 Volts on balanced is a standard. You have to check what is maximum possible input on your amp. On my McIntosh is 16 Volts.
I have pass labs XP22 preamp and x250.8 amplifier. I couldnt find any spec rating in the manual
Accuphase E5000 the maximum is 5 V
I put 4 V
Tom T.
I did the same.
I was prejudiced against Delta Sigma DAC’s harsh sound but the RD 160 doesn’t have it.
The Harmony is now in my second system.
This is my experience so far. I have had the rs130 rd160 combo for the past 4mths, and i keep coming back to Slow filter. With my system the super slow introduce more extended bass but can slightly muddy midrange sound, the short sharp default filter is clear but lacks abit of vocal bass and holographic.
I concur, I have the same observations between the RS130 and RD160. The slow filter in the RD160 seems to offer the most magic.
@88hht
What type of connection did you use between the RS130 and the RD160?
I am using amphenol cable, waiting for more feedback on sfp, so far it seems to be mixed and amphenol seems to be a good middle ground and cost effective.
I have some supra ixlr cables coming this week for the connection from dac to preamp and to amp, replacing my cheap mogami gold, hopefully it makes further improvement.
slow - bypass and volume at 80
i found slow more spacious and revealing through ra180.
I use the dsd mode default filter, together with the RA280. In the PCM upsampling mode I find the bass a bit too slow.
The RD160 filters are designed to offer different sound characteristics, and preferences may vary depending on system configuration, playback mode, and connections. Many users prefer the Slow filter for its natural sound and spaciousness, while other filters emphasize clarity and speed.
Differences between PCM and DSD modes, amplifier matching, and connection types are expected and part of normal operation. Your feedback is valuable and will be considered for future firmware improvements.
I got best sound from rs151 … I also use ddc and gustard r30. I personally like r2r sound. Rose should make a ddc like mutec mc3, and a r2r dac , or tube dac. You should research HDR dac ok??
@Bicycle
I will share your suggestions with both our software team and hardware team.
