Remote BT doesn't work anymore after update
Remote BT doesn’t work anymore after the update. I tried to link the BT remote again. It shows but am not able to link it anymore to my RS150B
Hello @Tom_one
Can I try connecting the BT Remote again after factory reset?
Rose device—>Settings—>System Settings—>Factory Reset
This link explains how to connect the BT Remote
(77) Hi-Fi Rose | Pairing your Remote - YouTube
Hi @ROSEHAN,
Well, I didn’t reset. I should shut BT on the RS150B of and on. After that, I could reconnect the remote again.
thank you for your suggestion. But hitting the factory reset on all little bugs is not something I want to do.
Thank you for your comment; I tried your suggestion and it worked perfectly as I was having the same issue after the firmware update. Much better/easier than doing a factory reset!
