Remote control - 150b
Hello. 150b does not see the remote control. The scanning doesn’t even seem to start. Is it possible that it has something to do with the 5.2 system currently installed?
@Vlad
I didn’t understand your question.
  1. What do you mean you can’t see the remote control on RS150b?
  2. Do you mean that RS150b cannot be operated with the remote control? The videos in and are related to remote control pairing.
    www.youtube.com/watch?v=gTHcLYe-OwA
  3. Please provide an accurate and detailed explanation so that I can give you an accurate answer.
I am familiar with the procedure for setting up the remote control, but after I picked up the 150 from the service, after turning on the Bluetooth, the scanning process does not begin - which means I cannot connect the remote control.
@Vlad
Please check a few things.
  1. Does the same symptom appear even if you replace the batteries in your remote control?
  2. Is your remote control properly connected to the Rose device via Bluetooth?
  3. If the remote control does not work even after trying the above two steps, contact the distributor in the country where you purchased the Rose device and request a remote control.
Same problem for me. Whom do I contact in Toronto Canada and will they replace the remote for free?
@HJK
The distributor in Canada is MOFI Distribution.
Here is the information about MOFI distribution.
TEL : (+1) 312 738 5025
URL : https://www.mofidistribution.com
