Remote Control Advice
How do I change the display brightness using the remote control please?
I can get to the menu and can highlight ‘display’ but I can’t get the remote control to jump across to the next menu section (from Edit Home menu downwards).
Many thanks…
Thanks for the suggestion, that works!
