Remote Control Design
the remote control should be slightly rethought. First of all, the timer button is in a poorly chosen position resulting in unwanted activations. Moreover, I think all the buttons on the remote control should be lit. It is very difficult otherwise to deal with it and I think this fantastic product deserves such a premium accessory. Please redesign the remote control
thx
We received some opinions to improve remote control and we are working on it.
We will try to present it as quickly as possible so that there is no inconvenience.
Thank you for your feedback.
Maybe a solution like Lumin created for their streamers
Via USB the Lumin approach
https://www.luminmusic.com/lumin-ir-control-package.html
gr Ton
The new aluminum clad Rose remote control is an embarrassment for a premium quality product. The cheap plastic keys are very small and the design does not meet the de facto standards for audio-video remote controls. For comparison please review the Yamaha RAS35 remote that I use for the Yamaha A-S 2200 integrated amplifier. I would like you to produce something similar, otherwise this remote will be abandoned in the toy box. I have nothing but praise for the Rose 1560B product. It integrates perfectly with Yamaha A-S2200 and Triangle speakers.
