After the latest upgrade the remote cant communicate with the 150B, it find the remote when i search but says ”cant communicate with RCU”, Anyone out there knows why?
Yes, all in the manual.
Yes it is, now it work, i had to reset the remote in the little hole under the light, after that you could pair…
