My remote control is paired and it shows on the list od paired devices but it does not work at all. Main unit does not respond to any of the commands send from remote control. I did reset by removing batteries and re-pairing but it did not help.
In bluetooth display of RS250, is ‘ROSE MCU’ under ‘Paired Devices’?
Also, is it in gold color?
OK, now it works! Thank you for swift response and support!
