So far unit is very cool looking and where it excels is in sound quality, but I am sure some “software (firmware)” updates will be needed to work the kinks out. Here are some issues see below:
Remote and Use of External Hard Drives?
1.) Currently my remote is paired and everything except the - button for down volume does not work, I just received it today and it will not turn down volume, only if you physically push down very hard will it work, so the remote itself is bad.
2.) How can one get an external hard drive to be recognized by this unit? I have several 5TB drives and no matter how I plug it in it will not be recognized. I am thinking of buying an internal one soon.
3.) Ordered unit through Music Direct, do I need to go through them to get a new remote or do I have to return the whole unit?
4.) Unit occasionally locks up and freezes then needs to be re-booted, if these issues above are resolved, I would give this unit a 9 out of 10… But right now, unsure… If you can transfer files easy, or you can use an external HD Drive and use your own music and stream at the same time, this would make a killer unit. I sold my Sony HAP, as it would not stream and copying files was just too slow.
Thanks for any help!
