After upgrading to EA, the remote stopped working. I have reconnected it to the 150B that I have and changed batteries. In the UI the remote shows up as “Paired” but it does not work.
Is this a known error and does it have a known remedy?
Kind regards
Reinhold
@Rekon001
- When you access Bluetooth on your RS150b, is the Rose RCU located as a paired device and displayed in gold?
I would like a picture of your RS150b bluetooth screen.
- On the RS150b Bluetooth screen, press and hold the Rose RCU to delete it and try pairing again.
www.youtube.com/watch?v=gTHcLYe-OwA
- Does Wi-Fi work properly on your RS150b?
- Does the same symptom appear even if you factory reset your RS150b?
RS150b->Settings–>System settings–>Factory reset
I believe the issue is a remote control or dongle issue.
If the above does not work, contact the distributor in the country where you purchased RS150b and request a new remote control and dongle.
distributor.roseaudio.kr
- No, in white.
- Done with the same result.
- Yes it does.
- After factory reset and reinstallation the error remains.
I will contact the reseller Audio Concept in Sweden for a replacement of dongle and remote.
It worked perfectly well before update to EA.
Kind regards
Reinhold
