Is this standard behavior even if not chosen deliberately? I want the playing to just stop when a playlist is finished.
If you want the last song in the playlist to play and stop, the last song in the playlist must be the last song in the queue.
And if you look at the picture below, the button marked in red should be white.
Thanks. I think I understand what happened in my case:
I play files from an internal SSD using folder and file selection. For instance, when I select track 4 from a folder that contains 4 tracks, track 4 starts to play but the playlist now looks like this:
track 4 (playing)
track 1
track 2
track 3
So after playing track 4, it starts track 1.
But it seems solved now after choosing “Clear queue and add song” in Audio settings.
