Required Android Operating System
What is the minimum required Android operating system to run RoseConnect Premium? I assume a current Samsung tablet running Android 10 or 11 should work? Thanks.
Currently, RoseConnectPremium works from Android 8. (Do not work on Android 7)
However, I would recommend to use from Android 10, since Android 8 is also an old version that may not be usable either via update.
Great, thanks! Just what I needed to know. I’ll use at least 10.
