Little confused as this is new to me. I’m streaming Tidal Hifi plus from the 150B to my Mac preamp via Balanced XLR cables, should I set the PCM resampling Frequency to the highest settings? The max Sample rate of 394kHz and the max Resample rate to 384kHz to get the best audio quality?
If you set the resample rate to original in the PCM resampling frequency, the sound source will be output as is.
You may or may not set the Max sample rate. Compare and listen and set the resample rate to the original or 384kHz.
