Is someone using a different resample rate as the Original setting in the RS 130?
What are your experciences?
I am using usb and also AES.
I have tried and can confirm it works. But sadly you can only configure the sampling rate and not the bit depth. So in my case I got 32bit/96Khz instead 24bit/96 Khz I like to send to my DAC.
Soundwise I had less time to check seriously, because I stop the experiment regarding the bith depth problem.
