Rescan of media library
Does your scan problem still exists? I have a similar one…would be nice to have a update on this.
Yes, the scanning problem still exists after nearly 1.5 years. HiFi Rose have answerd that it is hard to solve the problem with very long scanning times. We are not getting any answer why from then.
For now I have my music stored on a Synology NAS. The music is stored in folders according to genre. The library consist of 20 TB music. Take days to do a rescan if I added a new ripped CD.
Workaround for shorter scanning times:
My solution to the long scanning times was to create a new folder on my NAS that I called “New Music” and added a new DB in Rose Media Librarary. When I have added a new ripped CD I put it in the folder “New Music”. I then delete the database “New Music” in Roses Media library for that folder and thereafter create a new database that would be scanned. The scanning now takes 15 minutes and the DB-Caching will take 65 minutes.
Nice workaround, functional but very unsatisfying for you.
Probably think about ROON, I can recommend ROON highly (best user experience, best scan times - I estimate around 30sec for your library with 275‘000 tracks).
I have Roon (lifetime subscription) and I agree that Roons interface is 100 times better than the Rose app.
Sadly, in my system when playing music the sound from the Rose app sounds better than the sound from Roon. That’s why I still use the Rose app.
I know that there is people that say that it is impossible that there is a difference in the sound, but I hear a difference to Rose apps advantage in many aspects.
That sounds absolutely reasonable for me. I always trust my ears and have optimized my system in every aspect, always trusting my ears.
In my setup (Genelec 8351B Active Monitor with integrated A/D, D/A, DSP, Mutec MC-3+ USB with activated Reclocking, Audioquest Niagra Power Conditioning and power cables, and now the RS130 streamer as a digital source) I have to spend more time for comparing this two sound paths to decide which sound better. There are so many options (e.g. upsampling or native resolution) to try, so it’s really time consuming. Especially because my Genelec has a internal signal path of 24/96kHz, so I experimenting a lot with upsampling to 24/96 (favored within ROON, because I have a dedicated i7 NUC with ROCK installed).
You’d hope that at least technical people would know that ears are the last thing to be trusted.
There is absolutely no technical reason that one bit-perfect software would sound different from another bit-perfect software. That’s like expecting that your bank balance will be higher if you log on to your bank with Mozilla instead of Edge… Don’t get me started on Fraudioquest :slight_smile:
Fur sure, bit-perfect software sounds always the same, but every change in your playback setup can make a difference in sound, not always in better or worse, but very often in sounding you like more or not. Thats why we are talking all about…
Can and will are different things though. Turning on Muse in Roon will (probably) make an audible difference. Using Rose Player (or foobar) instead of Roon, or replacing the power cord with $10K one will not…
Please Boris, why don’t you stay at ASR with your psedou science and measurement arguments and leave us that believe (imagine :pleading_face:) what we hear in this forum.
Please don’t respond to this. You are on a dead end street.
A nice response would be to quote “You are entitled to your own opinions, but not your own facts.”
A less nice but more approipriate response is “When I need some willfully ignorant flat-earther to tell me what to do or not do on the Internet, I will notify you in writing.”
But it is, indeed, a dead-end street. Some people just aren’t intelligent enough to even want to learn.
This is so disappointing. Took delivery of a new 150b on Friday, now Sunday and still scanning. Yes I’m an audiophile and so have a large music library like many others. Sonos scans this in about 10mins.
I wouldn’t mind so much but this is a VERY expensive piece of kit, not a cheap eBay item.
Rosehan,
I’m having difficulty connecting via smb from my Mac Studio to my RS130 internal SSD. I have not had this problem in the past. I suspect this is due to the smb not connecting to the RS130 while the Db scan is running? Am I correct? If not do you have any other suggestions?
Time is money, Rose burn our time on scanning DB.
Because you have to sit and wait in front of your player until it finishes? :grinning:
